AirPort/Bluetooth Board
2 Answers 1 Score |
My Optical Drive ejects discs after I insert them. |
2 Answers 3 Score |
My iBook is not booting, full speed fan, black screen |
1 Answer 2 Score |
Why my monitor is showing vertical lines and freezing after the boot? |
2 Answers 3 Score |
install OS X 10.5 from a bootable USB HDD? |
Parts
Tools
These are some common tools used to work on this device. You might not need every tool for every procedure.
Troubleshooting
Track down a number of hardware problems using the iBook G4 12" 1.33 GHz Troubleshooting Guide.
Upgrades
There are a number of components in the iBook G4 12" 1.33GHz can be cost effectively upgraded.
- Memory: The iBook G4 12" 1.33GHz has one RAM slot. You can add up to 1 GB of memory to your computer. Check out the RAM category, or check out our easy iBook G4 12" 1.33 Ghz RAM installation instructions.
- Hard Drive: Browse our hard drives and upgrade today.
- Optical Drive: The 24x Combo Drive allows you to read both CDs and DVDs and write CDs. Look through our optical drive category for additional optical drives. Install your new optical drive yourself, the easy way.
Identification and Background
Use the laptop identification system to help you identify your machine. iBooks tend to look very similar, and it's important to know which machine you have before ordering any replacement parts.
